How to interface STM32f767zit6 with ethernet rotary encoder using ethernet communication?
RSing.17
Hello, I wanted to interface and get the readings from ethernet/IP encoder from Fraba with stm32767zit6. Is there any way to communicate it stm32f767zit6 and get the data from the encoder.
PS- Below is the datasheet of the absolute rotary encoder which I am using.
Related / Dupe ​https://community.st.com/s/question/0D53W00002FbMg7SAF/can-anyone-help-me-interface-my-stm32f767zit6-board-with-ethernet-with-detailed-explanation
What board do you have, you mention a chip, do you have the NUCLEO board, or something else?
E​xpect to have to read the specifications and implement a TCP/IP protocol stack so you can send / receive packets
The board is stm32f767zit6 NUCLEO
