F407 and lis3dsh
Konstantin Maslennikov
Posted on February 23, 2018 at 15:01
I'm try use only registers for lis3dsh.
https://community.st.com/external-link.jspa?url=https%3A%2F%2Fgithub.com%2Fmas-kon%2FF407-LIS3DSH
- my code. This code sometimes is worked, but sometimes it stopped. Can any help my?
#cmsis #registers #lis3dsh
Note: this post was migrated and contained many threaded conversations, some content may be missing.
11 REPLIES 11
Andrew Neil
Posted on February 23, 2018 at 15:17
So what debugging have you done?
Posted on February 23, 2018 at 16:08
Anytime funtion
uint8_t SPI1SendData(uint8_t data)
while (!(SPI1->SR & SPI_SR_TXE)){};
SPI1->DR = data;
while (!(SPI1->SR & SPI_SR_RXNE)){};
data = SPI1->DR;
return data;
return 0xFF.
Why, I don,t know...
Posted on February 23, 2018 at 16:12
Looks like CS (chip select) is not enabled or sensor internal register address embedded in data sent to the sensor is wrong
Posted on February 23, 2018 at 16:58
Have you actually looked at the SPI lines on an oscilloscope to see what's happening ?
Posted on February 23, 2018 at 17:01
I'm have not oscilloscope..
Andrew Neil
Posted on February 23, 2018 at 19:22
Similar question just posted:
https://community.st.com/0D50X00009XkgQkSAJ
Posted on February 23, 2018 at 19:21
You're pretty much stuck when it comes to hardware debugging, then.
Posted on February 23, 2018 at 20:13
http://www.st.com/content/ccc/resource/technical/document/datasheet/23/c3/ea/bf/8f/d9/41/df/DM00040962.pdf/files/DM00040962.pdf/jcr:content/translations/en.DM00040962.pdf
Check wiring. CS needs to be set to 0 when want to read / write through SPI.
Posted on February 23, 2018 at 20:20
It's stm32f4-disco..
