paul-henri
Ethernet on STM32F4 Discovery
Posted on August 06, 2013 at 11:15
Hi everyones,
I am searching a Ethernet breakout board for my eval board. I saw on this
http://blog.tkjelectronics.dk/2012/08/ethernet-on-stm32f4discovery-using-external-phy/
 that he is using the
DP83848 Phy breakout board but it seems difficult to find such a board.
Thus, I found an other one you can see it on this
http://radiospares-fr.rs-online.com/web/p/kits-de-developpement-pour-processeurs-et-microcontroleurs/7581032/
 and characteristics seem also good.
So, can you confirm me I can use this board as an ethernet module for my STM32F4Discovery board ?
Thks.
#stm32 #discovery #ethernet-interface
paul-henri
Posted on August 06, 2013 at 13:06
Yes but you didn't answer my question, I wanna know if  the other board can be used with STM32F4 ?
069349773
Posted on August 06, 2013 at 14:19
I think that it can, but there isn't examples. You will need to work with SPI
Tesla DeLorean
Guru
August 6, 2013
paul-henri
Posted on August 06, 2013 at 17:05
Indeed, you may be right, it would be easier to use the base board provided by ST. And with their standard library, I think I can be comfortable :)
It's kinda more expensibe but It should be the best solution to me.
Thanks again for your advices clive1.
