FLueb
Connect to target fails with "Failed to execute MI command:"
  • September 27, 2021
  • 6 replies
  • 1581 views
Error in final launch sequence:
target remote localhost:61234
Error message from debugger back end:
localhost:61234: Das System hat versucht, einem Verzeichnis, das sich auf einem mit JOIN zugeordneten Laufwerk befindet, ein Laufwerk mit SUBST zuzuordnen.
    Jocelyn RICARD
    Hello @FLueb​
    your error message is strange. It seems to show you are not using local drive.
    I've never heard about this JOIN.
    Do you have a specific setup ?
    Best regards
    Jocelyn
    FLueb
    FLuebAuthor
    The Workspace and all related content ist on a local drive.
    Path is quite simple:
    C:\Azure-RTOS-WS\workspace
    Jocelyn RICARD
    Hello @FLueb​
    OK thank you for your feedback.
    I still have no idea what is going on.
    Could you try
    1) Start from scratch with new workspace (you can just erase this one which is fine for location) and do each step again.
    2) If issue is still there, try to change in the debugger configuration (Run/Debug configuration) in tab Debugger, the debug probe from ST-Link (ST-Link GDB server) to ST_link (Open OCD).
    Also, try using another USB cable. I don't think this is the issue but just in case...
    Best regards
    Jocelyn
    FLueb
    FLuebAuthor
    ST_link (Open OCD) has same problem
    FLueb
    FLuebAuthor
    Probleme solved. Was related to usb-hub
    Jocelyn RICARD
    Hi @FLueb​
    Great that you solved this issue.
    That is one important information !
    Thank you for your feedback.
    Best regards
    Jocelyn
