Jan 9, 2025 3:21 AM UTC
Cannot Extract STSW-SAFEA1-MW
I am having trouble extracting the STSW-SAFEA1-MW. This is the same issue mentioned here and here. I can't use your product if I can't use your drivers. A fix would be appreciated.
Peter BENSCH
Peter BENSCHBest answer
Jan 9, 2025 7:33 AM UTC
Welcome @rlederhose, to the community!
I also tested this again after @Frantz LEFRERE tried it here and also had problems with some unzip programmes. However, the ZIP can be unpacked very well with the open source (un)packer 7-z.
Hope that helps?
/Peter
Peter BENSCH
Hope that helps?
/Peter
Jan 9, 2025 11:05 AM UTC
Thanks for the help Peter! 7zip worked a treat.
