Can't get the STM32H7 USB audio HS example to work
Hi there,
I've got a new STM32H743I EVAL board and am trying to run the USB audio HS example provided with stm32cube_fw_h7_v130.
The Full-speed example works fine.
I'm using the correct USB connector, my PC (Windows 10) recognises the device and says it's working properly. When trying to play audio, windows is unable to start the stream, and no audio plays from the headset output.
I've tried debugging the USB core interrupts and some requests are being processed, but no audio endpoint stuff.
Any ideas where to look?
Many thanks,
Matt
