NASI
Call HAL lib inside Call back
  • June 1, 2022
  • 944 views
Is it Ok to read GPIO pins inside a timer call back as follow:
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef* htim)
if (htim == &htim2 ) //15 ms
BT1 = HAL_GPIO_ReadPin(GPIOx, Pin_x);
BT2 = HAL_GPIO_ReadPin(GPIOx, Pin_x);
BT3 = HAL_GPIO_ReadPin(GPIOx, Pin_x);
Thank you
KnarfB
It is. Look at (debug step) the implementation.
hth
KnarfB
Andrew Neil
