federico.massimi
Where connect SMPS pins when SMPS is not used.
  • April 7, 2023
  • 1 reply
  • 2393 views
Hi, I'm using an STM32H745IIT6, in the package I have there are also the SMPS pins. But in my application I don't have to use the SMPS.
The question is, what should I do with these pins:
_legacyfs_online_stmicro_images_0693W00000bhiesQAA.pngSearching the internet, I saw that someone connects them all to ground, but I haven't found any explanatory articles or clear indications. Can you tell me how should I connect these 4 pins when I'm not using the SMPS?
Thank you.
Best answer by KDJEM.1
Hello @federico.massimi​ ,
Below is diagram from reference manual RM0399 showing different hardware configurations for power supply.
_legacyfs_online_stmicro_images_0693W00000bhnBvQAI.pngSo, when the SMPS is OFF the VDDSMPS, VFBSMPS and VSSSMPS should be connected to ground and VLXSMPS should be floating.
Kaouthar
1 reply
KDJEM.1
KDJEM.1Best answer
Kaouthar
