Feb 24, 2024 5:05 PM UTC
Firmware
Hi, i have build up  Normal mode program For CAN on  board (stm32f103c8t6) setup. It is showing that data is transmitting but when I tested on board there no Data
Can you tell me what is the problem??
Tesla DeLorean
Tesla DeLoreanBest answer
Guru
Feb 24, 2024 8:05 PM UTC
This isn't a magic show, you'll need to present your software and hardware in a way others can understand what you have created.
CAN will need a transceiver to get to a bus, and the bus will need a responding device also attached to it.
In Loop-Back mode you could use a scope on the CAN_TX pin to see a signal.
Tesla DeLorean
Guru
Feb 25, 2024 12:23 PM UTC
I have created bus to
Feb 25, 2024 12:24 PM UTC
The board I am using it will not work for loopback mode
Tesla DeLorean
Guru
Feb 25, 2024 1:55 PM UTC
Still seems to lack any material presentation of what you're doing
