Designing custom Board
  • April 9, 2024
  • 8 replies
  • 2559 views
for a DIY project including LoRa ra-02, MPU6050 and NEO-6M i have purchased some Blue pills from a vendor but it turned out they are fake blue pills (STM32F103C6).
I am trying to make a RC, so i have a Transmitter which needs 2xSPIs (one for LoRa and one for a TFT Display).
The fake blue pills i have, they do have only 1x SPI therefore i have decieded to design my own Board.
Requirement for the Transmitter:
2xSPIs (LoRa and TFT)
5 channels ADC
For the Receiver:
1xSPI (LoRa)
1xI2C (MPU6050)
1xUART (NEO-6M)
1xADC (Battery voltage monitoring)
I have searched on the net for a schematic of the Blue pill and found so many but no one with a BOM so i can select the right Materials.
E.g. for the HSE ocsi, there are many 8MHz osci out there but how should i know which one is the right one for my Board.
Is there any form ST hardware design reference or something like that so i can benefit from?
Andrew Neil
Why, yes - there is!
https://www.st.com/resource/en/application_note/an2586-getting-started-with-stm32f10xxx-hardware-development-stmicroelectronics.pdf
On the specific question of oscillators:
https://www.st.com/resource/en/application_note/an2867-oscillator-design-guide-for-stm8afals-stm32-mcus-and-mpus-stmicroelectronics.pdf
See also:
https://community.st.com/t5/stm32-mcus-products/mems-oscillators-not-compatible-with-stm32f1-and-stm32l1-series/td-p/654210
You should go to the Product Page for the chip you intend to use, and look on the 'Documents' tab - that will list all the available Application Notes, etc; eg,
https://www.st.com/en/evaluation-tools/nucleo-f103rb.html#documentation
You can also look at the schematics of ST's boards - go to the Product Page for the board, and look under 'CAD Resources'; eg,
https://www.st.com/en/evaluation-tools/nucleo-f103rb.html#cad-resources
Andrew Neil
Before designing a custom board - especially as a novice - I would very strongly recommend that you prototype & prove your design on an ST board first.
 A what?
Can't they share one SPI?
The whole point of a bus like SPI is that it can be shared by multiple devices.
hamoAuthor
Thank you for the reply.
I have already proved on a breadboard and everything is working.
RC = Radio Controller.
I do not want to share the same SPI between LoRa and TFT on purpose.
Sharing one SPI bus may affect the LoRa sensitivity (i think).
Andrew Neil
Eh??
It's just a digital control interface - the LoRa transceiver neither knows nor cares what else is on the bus, surely?
hamoAuthor
I would prove that on a Breadboard.
Would it make a difference if use SPI with DMA?
Andrew Neil
Again, the transceiver neither knows nor cares what is driving the SPI bus - so, as long as you keep within the slave's specifications, it will work.
Beware that solderless breadboards don't have great electrical characteristics - so the issue might no be so much about sharing an SPI per se as about the breadboard wiring ...
hamoAuthor
Ok, then you suggest i should make a prototype and then prove it.
I think that would be a good idea.
Andrew Neil
Definitely.
It is, of course, possible that the 2 devices might not "play nice" together - but they should.
