varo1111
Waking up from stand-by mode with both rising and falling edge on wakeup pin.
I have a STM32G030K6T.
Right now I can wake up from standby with either wake up pin falling or rising edge. How can I use both of these edges to wake up the device from stand-by?
HAL_PWR_EnableWakeupPin documentation says
 * @brief Enable the WakeUp PINx functionality.
 * @param WakeUpPinPolarity Specifies which Wake-Up pin to enable.
 *     This parameter can be one of the following legacy values which set
 *     the default polarity i.e. detection on high level (rising edge):
 *      @arg @ref PWR_WAKEUP_PIN1, PWR_WAKEUP_PIN2, PWR_WAKEUP_PIN4,
 *        PWR_WAKEUP_PIN5,PWR_WAKEUP_PIN6
 *     or one of the following value where the user can explicitly specify
 *     the enabled pin and the chosen polarity:
 *      @arg @ref PWR_WAKEUP_PIN1_HIGH or PWR_WAKEUP_PIN1_LOW
 *      @arg @ref PWR_WAKEUP_PIN2_HIGH or PWR_WAKEUP_PIN2_LOW
 *      @arg @ref PWR_WAKEUP_PIN4_HIGH or PWR_WAKEUP_PIN4_LOW
 *      @arg @ref PWR_WAKEUP_PIN5_HIGH or PWR_WAKEUP_PIN5_LOW
 *      @arg @ref PWR_WAKEUP_PIN6_HIGH or PWR_WAKEUP_PIN6_LOW
 * @note PWR_WAKEUP_PINx and PWR_WAKEUP_PINx_HIGH are equivalent.
 * @retval None
TDKBest answer
You can't select both edges for wakeup. The hardware doesn't allow for it. Look at the PWR registers in the reference manual.
1 reply
TDKBest answer
