2024-05-26 10:20 PM
Does anyone have, or know where I could find, a Radio Test / Radiated Emissions report for the ST25? It appears to have the appropriate approvals so the report should be available somewhere, but I just can't find it.
2024-06-10 07:04 AM
Hi jaseF,
there is no "direct" report available for this obsolete product.
But you can find under: https://cse.google.com/cse?cx=partner-pub-0545639743190253:3806177996&ie=UTF-8&q=as3993&sa=Search&ref=fccid.io/frequency-explorer.php%3Flower%3D800%26upper%3D1000
a selection of customer products which have used the AS3993. This IC is identical with the ST25RU39993.
So there are several reports available which use the AS3993/ST25RU3993 in their UHF RFID reader products...
I hope this helps.
Best regards,
Marcel
2024-06-10 07:04 AM
Hi jaseF,
I hope this helps.
Best regards,
Marcel
2024-06-10 07:38 AM
eol
