Is there a provision to read temperature sensor value using SDK of ST25RU3993-EVAL board?
Using ST25RU3993, I was able to get only the On-chip RSSI value and EPC,PC values.
Is reading the temperature sensor value, implemented in the SDK?
If NO, How can i implement it??
The temperature Sensor which I am using is "RFM3200-AFR"(Gen2 compatible).
