HShei.1
Visitor II
December 28, 2020
Hi there I am working with CR95HF-VMD5T 13.56 MHz transceiver and M24LR04E connected to STM32F1038T6 . How to save data reading by transceiver? Regards Hosein
  • December 28, 2020
  • 1 reply
  • 519 views
    Best answer by Brian TIDAL
    if I have well understood, you are using the M24LR-DISCOVERY kit with the CR95HF Reader being connected to a PC and you are reading data thanks to the "CR95HF_Development_Software" GUI on the PC and you want to save the data being read ?
    If my understanding is correct, I can then suggest to use the CR95HF DLL to build your own application. See AN3954 (Developing your own Visual Basic or C/C++ application on a CR95HF demonstration board).
    Rgds
    BT
    1 reply
    Brian TIDAL
    Brian TIDALBest answer
    Rgds
    BT
