Jul 22, 2024 12:27 PM UTC
CR95HF DLL for x64
Good morning, I'm looking for the sources of the USB communication library for the CR95HF DLL, unfortunately the downloadable library is only for 32 bit systems, I would need the sources to be able to compile it at 64bit and eliminate the problem.
Can anyone help me solve my problem?
Brian TIDAL
Brian TIDALBest answer
Jul 24, 2024 7:50 AM UTC
The source code of the CR95HF DLL 32-bits version will be provided to you in private.
Rgds
BT
Brian TIDAL
Jul 23, 2024 8:37 AM UTC
if I am not wrong, the CR95HF DLL has been ported to 64 bits inside the Software Development Kit for ST25  (STSW-ST25SDK001) in ST25SDK-1.11.0\readers\st\resources\windows\x64.
Rgds
BT
Jul 23, 2024 12:20 PM UTC
The DLL is 64 bit, the problem now is that the exported functions do not coincide with those present in the old one.
Like:
CR95HFDLL_USBconnect
CR95HFDLL_USBhandlecheck
CR95HFDLL_getHardwareVersion
And all other function if i dump exported function:
Dump of file cr95hf.dll
File Type: DLL
Section contains the following exports for cr95hf.dll
00000000 characteristics
592E8352 time date stamp Wed May 31 10:48:18 2017
0.00 version
1 ordinal base
10 number of functions
10 number of names
ordinal hint RVA name
1 0 00001E70 Java_com_st_st25pc_model_rfReaders_st_STReader_antiCollision
2 1 00001500 Java_com_st_st25pc_model_rfReaders_st_STReader_connect
3 2 000015E0 Java_com_st_st25pc_model_rfReaders_st_STReader_disconnect
4 3 000014F0 Java_com_st_st25pc_model_rfReaders_st_STReader_echo
5 4 000015F0 Java_com_st_st25pc_model_rfReaders_st_STReader_getName
6 5 000015D0 Java_com_st_st25pc_model_rfReaders_st_STReader_isConnected
7 6 00001640 Java_com_st_st25pc_model_rfReaders_st_STReader_selectReaderMode
8 7 00002060 Java_com_st_st25pc_model_rfReaders_st_STReader_sendPps
9 8 00001FA0 Java_com_st_st25pc_model_rfReaders_st_STReader_sendRats
10 9 00001950 Java_com_st_st25pc_model_rfReaders_st_STReader_sendReceive
I can't find any reference to the old APIs of the previous version, this one seems like a totally different version.
Brian TIDAL
Rgds
BT
