Using an A5974AD for DC-DC conversion 5V to -12V
I used A5974AD in my circuit board for converting 5V to -12V.
But, there is a lot of noise there on power.
When I changed adapter 5V 2A to 5V 3A, the problem was solved.
Here is a question.
Is this symtom related to 'limit of 2.5 A switching regulator with a minimum switch current limit of 2.5 A' in datasheet?
https://www.st.com/en/power-management/a5974ad.html
If yes, please tell me more detail about it, or no, tell me the reason for this problem.
Thanks,
