STEVAL-WBC86TX PCB Layout
I've had a look at the STEVAL-WBC86TX PCB design and have concerns on the routing over the split plane.
The STM Webpage doesnt seem to work for the STEVAL-WBC86TX but ive managed to find the Gerbers. You can see in the images below, the top layer and layer 1. The trace going to one side of the coil is routed over split planes. Isnt this bad practice?
As the website is down, I can only assume that this hasnt had any compliance testing done, as its an evaluation board.
Thanks,
Mike
