The size of the board, i.e. the PCB, can be derived from its GERBER data.
Regards /Peter
Currently there is none available. It is an evaluation board that is only intended for evaluation and not for use in an end product. So why do you need a 3D model if you have to develop your own board for your project anyway?
Regards /Peter
This development board meets the needs of our team, so we need 3D models to build the platform. If ST does not provide a model of the board, is there any information about the size of the board so that I can design the model myself? thank you.
Regards /Peter
