L6474 stall detection
Andre1
Posted on May 25, 2013 at 00:01
Hi
Can one implement stall detection on the L6474?
Andre
Enrico Poli
Posted on May 28, 2013 at 10:02
Hi Andre
Unfortunately it is not possible to implement this feature using the L6474.
larken
Posted on June 26, 2014 at 04:05
Enrico, do you know how to impliment anti resonace control in a stepper driver ?  Some stepper drives have it.
Enrico Poli
Posted on June 30, 2014 at 17:51
Damping the resonances of the stepper motors through an electronic control (electronic damping) can be very complex.
First of all you need a feedback which identify the resonance condition (usually an high resolution encoder) and than you need to drive the motor coils in order to generate a proper damping stimulus.
In general the resonances are dampen using mechanical systems shifting the oscillation frequency out of the operative range.
Enrico
