L6235 internal logic and temperature ratings
Posted on May 14, 2014 at 18:21
I have 2 questions that I've posted to online support but haven't received a response.
(1)I need clarification on the BRAKE input function - does it always short the 3 HS mosfets, independent of the ENA signal? I have independent signals driving the ENA_H and BRAKE_L pins
(2)What are the cold-temperature limitations of this part? What is the distinction between 'max operation' at -40C vs. 'recommended operation' at -25C? What are the potential issues at -40C? What behavior might be expected at -55C (ignoring packaging-related issues)
? Thanks, Kevin Spahr #l6235-bldc
