Heating on VIPER22ADIP-E
- 3 replies
- 1630 views
Hi STMicroelectronics team,
I am using VIPER22ADIP-E to design 15V, 5W power supply with input supply of 230Vac with diode bridge rectifier.
The schematics file is attached here,
When i am loading it with 5W load, the IC VIPER22ADIP-E is get heated and frequently turning off due to internal thermal protection. However, IC's power rating is recommended up to 12W (for US i.e. 85-265Vac) and 20W (European i.e. 195- 265V) is provided in datasheet.
What is wrongs in design?
Please suggest solution.
Thanks and Regards
Pemendra Kumar Pardhi
Sr. Design Engineer
CastNX Pvt. Ltd. Dewas
