Electrostatic discharge voltage capability of Diode STTH1602CT
NJasa.1
Is STTH1602CT Diode having Electrostatic Discharge voltage capabilities? if yes then how much voltage? Because its not mention in datasheet.
Nandish Jasani.
Dario CUCCHI
Hello @Community member​ ,
The STTH1602CT is a standard dual diode with common cathode.
The two diodes have forward and reverse maximum voltage, as specified in the datasheet.
If you need to use a component in your system for ESD protection, I can suggest to visit the ST dedicated page here.
All the best !
Dario CUCCHI
All the best !
Announcement
