Connect NUCLEO-F746ZG LoRaWAN Gateway to TTN
  • May 28, 2025
  • 3 replies
  • 455 views
In TTN, it says my gateway is connected to other cluster.
I'm not able to change it to connected.  What should I do?
Andrew Neil
Are you sure you have the correct ID for your actual gateway?
If you've just used a default, someone else has already registered that ...
KaaviyaAuthor
I have not used a default gateway ID . I have used the actual ID only. What should I do?
Andrew Neil
Where did you get that ID ?
