allenby
st6 + HDS2
  • August 21, 2003
  • 3 replies
  • 1011 views
Posted on August 21, 2003 at 09:18
st6 + HDS2
allenby
allenbyAuthor
Posted on July 08, 2003 at 13:59
When first powered on, my HDS2 starts in the run state - if I'm lucky it stops after 5-15 minutes and then RIDE or WGDB6 can communicate with it...
Does anyone have any idea why ??
Allenby
guy23
Visitor II
August 19, 2003
Posted on August 19, 2003 at 11:12
Try to power up the EMU before connecting the parralele LPT cable...perhaps your PC is introducing power through this cable and it disturbs the whole internal reset of the EMU.
manochavikas
Visitor II
August 21, 2003
The emulator starts in run mode if the clock source is a signal input on the probe board (OSCIN position).This problem can get removed by two ways:
1.by giving power to the probe board.The probe board gets power when we connect application board and give it power.
2.by removing IC (74HC04) from the probe board.
