M95M01-A125 EEPROM data corruption by power cut off
  • December 20, 2024
  • 775 views
Dear Sir
We use M95M01-DWDW3TP/K EEPROM in device to store log data
If power is cut off during its write cycle,  the data in writing address will become corrupted as I known.
In other hand, will other data, which was successfully written in other address, become correpted?
What I am concerned about is the impact to other existing data, when power cut off in the data writing process
For an expample, there are "address A" (successfully written) , "address B" (will written log data in it), "address C".(successfully written) .
If power was cut off when writing data into address B, is the content in address A and C corrupted too or not?
Waiting for your reply
Best answer by Andrew Neil
No.
But that doesn't account for misbehaviour of your software if you let it access the memory during a power failure...
So your system design should ensure that this can never happen:
  • Have power-fail/brown-out detection;
  • Ensure sufficient backup capacity to complete any ongoing memory access;
  • Block memory access once done;
  • etc, etc, ...
Andrew Neil
Andrew NeilBest answer
No.
  • etc, etc, ...
Dear Neil
I got it.
Thank you for your reply and adivice.
Roger SHIVELY
Hello @SHiroshi19 ,
This post has been escalated to the ST Online Support Team for additional assistance.  We'll contact you directly.
Roger
