RHolm
Hello, I`m using the SPWF04SA and after submitting a HTTPGET command(AT+S.HTTPGET=,/,443,0,,,,,,) I receive AT-SOK, but see no data in the console window. I expect only to get 10 bytes of information.
  • February 4, 2019
  • 1 reply
  • 670 views
    1 reply
    Elio Cometti
    Visitor II
    February 4, 2019
    ​Hello,
    I would expect this behavior when performing an HTTPGET to a TLS port, since the server would not recognize the handshake message and close the connection.
    Please check if port 443 requires TLS, in the case please use
    AT+S.HTTPGET=<domain_name>,/,443,2,,,,
    Please be sure to load the server's Root CA certificate before performing the httpget, otherwise the operation will fail.
    Elio
