wolf
Erase is not available on PROGRAM MEMORY for ST7FLITE10
  • November 18, 2005
  • 807 views
Posted on November 18, 2005 at 14:22
wolf
wolfAuthor
Posted on September 19, 2005 at 09:00
I try to use APISample-Software as command-line programmer with ST7STICK. If I enable the ''-erase'' option, the error message above is the only result.
This is the part of the source, that seems to make the problem:
// Erase a memory area.
// becareful depending on the device and on the memory area to
// process Erase may be unavailable
BOOL Erase(const char *szAreaName)
int iReturn=0;
unsigned long iAreaId;
if (IsErasableArea(g_szPrgDevice, ''PROGRAM MEMORY'')) {
if ((iReturn = EGetId(szAreaName, &iAreaId)) == 1) {
iReturn = EEraseAll(iAreaId);
else {
LDisplayError(''Unknown memory Area name'');
else {
char szErrorMsg[200];
sprintf(szErrorMsg,''Erase is not available on %s for %s'',
szAreaName,g_szPrgDevice);
LDisplayError(szErrorMsg);
return (iReturn==1);
Please help!
wolf
wolfAuthor
Posted on November 15, 2005 at 04:31
Thank you for reply. But why do I get an error message if I try to reprogram a read protected device?
Rene
