ST10F269 RTC PROBLEM !!!
pawel1
Posted on June 30, 2006 at 14:07
pawel1
Posted on June 25, 2006 at 13:53
Occasionally the RTCL RTCH register has decreases by a fixed amount (4096 or 16384). What is this??? Any suggestions? Thanks.
thomaskobler9
Posted on June 29, 2006 at 06:16
When using CAN2, the RTC regs gets corrupted!
pawel1
Posted on June 29, 2006 at 12:20
I don’t use CAN2….
Are you observing this problem randomly?
Yes.
Could you fix when you are observing exactly this problem?
Yes.
How are you detecting the RTCH decreased content?
I read value from RTCL RTCH every 1 sec.
I suspect the following points:
- What's the RTC basic clock frequency? May be you are not spying the RTCH register in real time.
I have external clock 11.0592 MHz and I init RTCPH RTCPL regs.
- Are you updating RTC registers in your code?
Yes. If occasionally the RTCL RTCH register has decreases, I fixed it.
- May be, you are unintentionally updating RTC registers?
Neila, please… :)
Pawel
