Memory Map Problem
baumann1
Posted on August 22, 2005 at 11:02
Memory Map Problem
baumann1
Posted on May 17, 2011 at 12:08
we used to use the PSD813 as program space and and EPROM in a socket as removable update-device.
Everything worked perfect. - It´s an 8051-arcitecture.
Now we use additionally for the first time the SRAM mapped in data space. During the update sequence we read from the EPROM, but now I will have to block or mask out the SRAM space.
Is it possible to do that by changing the PSD-registers?
Or what to do else??
please help!
Linus
jdaniel
Take a look at the definition of the ''VM'' register in the PSD data sheet. It controls what pins generate chip-selects for what pieces of internal PSD memory. You can use that to stop RD from accessing the SRAM.
