Floating Interrupt
thilo
Posted on May 19, 2003 at 07:13
Floating Interrupt
thilo
Posted on May 16, 2003 at 11:24
Hello all,
I have a question: what is the purpose of the floating interrupt input and how can I use them?
Thanks for your help.
rolf
Posted on May 19, 2003 at 07:08
Hi Thilo,
the floating interrupt input is usefull if your signal which is generating this interrupt is for example a TTL of CMOS signal. In that case you don't need an internal pull-up resistor.
An internal pull-up would cause an additionl current consumption if the external signal is low. Especially during a low-power mode this extra current should be avoided.
Rolf
sjo
This give you the option to use a pullup/down resistor of your choice rather than using the builtin pullup resistor.
SJO
