ongth60
Error:Vehicle fault detected!
  • June 17, 2005
  • 4 replies
  • 946 views
Posted on June 18, 2005 at 00:39
ongth60
ongth60Author
Posted on June 16, 2005 at 02:14
I'm facing problem connecting to my emulator:
The error stated is Error:Vehicle fault detected.
I suspect the emulator is spoilt. Pls advise.
Rgrds,
Ong
smartpocket
Posted on June 16, 2005 at 05:15
you can try to reduce the connection frequency from 8MHz to a smaller value
On ''Connection control'' window right click on your connection and select ''configure device info''. -->> Select new frequency.
bye
smart
ongth60
ongth60Author
Posted on June 16, 2005 at 08:42
What is the significance of the JTAG speed?
Rgrds,
Ong
ongth60
ongth60Author
OK.Thanks for the information.
Rgrds,
Ong
