RRain.1
Jun 23, 2022 6:33 AM UTC
What is the range of value of pull up resistor for LiS3DH for open drain outputs and how can we find the range?
10K Pull up is mentioned in the data sheet
    Eleon BORLINI
    Jun 24, 2022 6:27 AM UTC
    Hi @RRain.1​ ,
    did this thread solved your issue?
    Typically, I2C lines pull-ups range from 1kOhm to 40kOhm. 101kOhm is about in the center of this range. It's mostly related to the driving capability of the I2C pins.
    -Eleon
    RRain.1
    RRain.1Author
    Jun 24, 2022 6:44 AM UTC
    I want to know the resistor value in kilo ohms but the value you mentioned is in kHz.
    Please clarify.
    Eleon BORLINI
    Jun 24, 2022 6:45 AM UTC
    Sorry wrong unit measure from my side
    RRain.1
    RRain.1Author
    Jun 24, 2022 6:52 AM UTC
    How 1 - 40 K range is obtained?
    Eleon BORLINI
    Jun 24, 2022 2:38 PM UTC
    You might refer to documents like this.
    But in general the valued are determined at application level.
    -Eleon
