Pasi MYLLYMAKI
Question from Predictive Maintenance Webinar 29th of April: In a planetary gear, where defects change orientation constantly, is it possible to detect the vibration?
  • May 11, 2020
  • 1 reply
  • 420 views
    1 reply
    Vladimir JANOUSEK_34072
    Visitor II
    May 12, 2020
    In Gear systems, frequencies can be higher and IIS3DWB recommended for this reason for testing. This is very application specific in the end and ST does not provide these libraries off-the-shelf, although using the MotionSP SW package and FFT analysis you could make first analysis of the sensor data. There are many ST partners who can help to solve specific application needs.
