YGude.1
Minimum distance measurement by VL53L0X
  • March 18, 2021
  • 1 reply
  • 2193 views
We found variation in measurement reading below 4 cm. Kindly confirm whether it is possible to measure below 4cm using VL53L0X
1 reply
Eleon BORLINI
Hi @YGude.1​ ,
As far as I can see from Arduino community, they say:
"The datasheet does not specify a minimum range, but in our experience, the effective limit is about 3 cm."
I believe this is a limitation in the application more than in the device itself, but measures below this distance might be more tricky to deal with.
-Eleon
