Markin.Andrew
Visitor II
June 9, 2015
LIS3DSH noise problem
  • June 9, 2015
  • 0 replies
  • 712 views
Posted on June 09, 2015 at 15:36
I am using LIS3DSH accelerometer, sampling rate 100HZ scale = +-2G. What I see is from time to time is noise what is coming from one of the axis, I tried to add more decoupling caps, thy to change internal filter settings nothing helps.
Please see attached for your reference.
Thank you for the help.
Andrew
