YGude.1
How to use VL53L0X_CHECKENABLE_RANGE_IGNORE_THRESHOLD
  • March 18, 2021
  • 1 reply
  • 890 views
We tried to use VL53L0X_CHECKENABLE_RANGE_IGNORE_THRESHOLD.
But not found any effect on measurement reading.
If you share some input for way to use VL53L0X_CHECKENABLE_RANGE_IGNORE_THRESHOLD, then it will be very useful.
Best answer by John E KVAM
This theshold says to ignore the range if the signal is so low that it's likely to be a false target.
The coverglass returns a number of photons. (No glass is 100 percent transmissive.)
And if those few photons were to trigger a range, you would get a false result.
So this parameter is generally set to 1.5 times the number of photons the coverglass refects.
That way you only get a target when there really is one.
  • john
1 reply
John E KVAM
John E KVAMBest answer
  • john
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
