LWang.7
Visitor II
April 28, 2021
How to restore SensorTile.Box to factory defaults
  • April 28, 2021
  • 7 replies
  • 3545 views
I tried following this tutorial (https://community.st.com/s/question/0D50X0000BYnQt6/sensortilebox-not-connecting), but it looks like DfuSe is obsolete, and I should use the new STM32CubeProg tool. I couldn't seem to find any information on how to use the STM32CubeProg tool to restore to defaults. How do I use STM32CubeProg to restore to defaults?
    Best answer by Eleon BORLINI
    Hi @LWang.7​ ,
    please check this more recent post, that uses the STM32CubeProg tool.
    I agree with you that the DFuSe tool is obsolete, and that its drivers can conflict with the STM32CubeProgrammer one.
    In addition, you can find in attachment a video tutorial on how to use this tool together with the SensorTile.box kit.
    If my reply answered your question, please click on Select as Best at the bottom of this post. This will help other users with the same issue to find the answer faster.
    -Eleon
    Eleon BORLINI
    Eleon BORLINIBest answer
    Hi @LWang.7​ ,
    -Eleon
    Eleon BORLINI
    Here attached you can also find one of the last FW version, with the BootLoader section for the DFU programming.
    -Eleon
    HS.4
    Visitor II
    August 7, 2021
    Hi, I tried flashing this to the board and then all the LEDs stopped blinking. I am not able to discover the board via Bluetooth as well. Is there any solution to fix this?
    Eleon BORLINI
    Hi @HS.4​ ,
    please follow the steps suggested in the attached file.
    -Eleon
