How to Re-address IR sensor "STHS34PF80" as a slave in I2C network
I need to connect two "STHS34PF80" sensors on the same I2C bus ,so does the "STHS34PF80" ST_IR sensor have the option to change his address as a slave by SW or HW?
Federica Bossi
Hi @Abdelrahman_Elnahas ,
STHS34PF80 has only 1 SAD, there is no option to change it.
We suggest to use different I2C bus or a multiplexed I2C bus to sequentially control them.
Federica Bossi
