Hi, This is a question regarding ISM330DLC I would like to know how the acceleration sensitivity change was measured according to the datasheet. Did you took offset of the Accelerometer into account while calculating it?
KJose.1
Eleon BORLINI
Hi @KJ.2ose​ ,
the (accelerometer) sensitivity value is measured giving a known stimulus to the device (basically rotating up and down the device), and then subtracting the offset.
You might be interested also in the parameter "gain" of this Design tip.
-Eleon
Eleon BORLINI
Hi @KJ.2ose​ ,
-Eleon
