Customer is having issue with LIS2MDL offset cancellation. Can you help?
Mike Minnelli
Posted on January 16, 2018 at 21:24
   Here is their initialization code:
    i2c_LIS2MDL_Read_8Bit(LIS2MDL_WHO_AM_I, &b);
    i2c_LIS2MDL_Write_8Bit(LIS2MDL_OFFSET_X_REG_L,0x00);
    i2c_LIS2MDL_Write_8Bit(LIS2MDL_OFFSET_X_REG_H,0x00);
    i2c_LIS2MDL_Write_8Bit(LIS2MDL_OFFSET_Y_REG_L,0x00);
    i2c_LIS2MDL_Write_8Bit(LIS2MDL_OFFSET_Y_REG_H,0x00);
    i2c_LIS2MDL_Write_8Bit(LIS2MDL_OFFSET_Z_REG_L,0x00);
    i2c_LIS2MDL_Write_8Bit(LIS2MDL_OFFSET_Z_REG_H,0x00);
    i2c_LIS2MDL_Write_8Bit(LIS2MDL_CFG_REG_A,0b10001100);// temp comp, continuous 100hz data rate
    i2c_LIS2MDL_Write_8Bit(LIS2MDL_CFG_REG_B,0b00000010);// offset cancellation enabled
    i2c_LIS2MDL_Write_8Bit(LIS2MDL_CFG_REG_C,0b00010000);// block data
Does anything need to be modified or added?  Thank you.
Miroslav BATEK
Posted on January 17, 2018 at 12:01
You configuration is correct.
What kind of issue do you have? Can you please be more specific.
Posted on January 17, 2018 at 20:16
Customer is not able to get the auto offset cancelation working.
Posted on January 18, 2018 at 14:40
It is very vague statement.
Please provide register dump and datalog of X,Y,Z data with and without offset cancellation.
