Visitor II
Dec 7, 2023 3:53 AM UTC
ASM330 4D orientation/tilt interrupt issues
The ASM330 does not generate correct 4D tilt/orientation interrupt at higher rotational speeds of 200 RPM
It is configured for 4D Tilt detection with highest ODR and highest Range
Is there any rotational speed limit beyond which 4D orientation will not work?
How to resolve the issue? Is there any specific filter settings to be used or ODR to be configured to resolve this?
1 reply
Billy OWEN
Dec 8, 2023 5:03 PM UTC
Hi @kvijay
The forum moderator had marked your post as needing a little more investigation and direct support. An online support case has been created on your behalf, please stand by for just a moment and you will hear from us.
Billy
