SNorm.1
About building a device that uses Arduino uno to draw accelerometer data from 9-axis motion shielding on a 1.8 "TFT display
  • March 26, 2022
  • 1 reply
  • 808 views
I wonder if embrio can help me solve my problem. I have little programming experience. I'm trying to build a device that uses Arduino uno to draw accelerometer data from 9-axis motion shielding on a 1.8 "TFT display. I want to draw the data as close to real time as possible.
I found three sample programs that I think contain everything needed to do all this. I lack the expertise to correctly combine them
。 TFT graphic test
Simulation diagram
9-axis shield sample: accelerometer
From the accelerometer example, I only need one axis to draw the graph. I was thinking that I could replace the potentiometer voltage in the TFT graphic example with this data.
Thank you very much for any help.
Thank you!:)
    1 reply
    Eleon BORLINI
    Hi @SNorm.1​ ,
    which accelerometer are you using?
    In any case, I would suggest you to post the same question in the Arduino forum.
    -Eleon
