X-NUCLEO-BNRG2A1 range is less than 10M on highest power level
MZann.1
I am experimenting X-NUCLEO-BNRG2A1 board and I have found the range is not as I hoped (about 5 Meters without any barrier).
I have set the power to 1,7 which I believe the highest power level +8dbm.
Is there any way to extend the range?
Does using external antenna help? or should I use an amplifier?
Does ST make any part for this purpose?
Thanks,
Mahmoud
0 REPLIES 0
