There is a package named STSW-QUUPPA-ETAG when I am extracting the zip file the Middleware is not present in it due to which the IAR workbench is not able to build the project successfully.
Sahiba Kaur
Peter BENSCH
Welcome, @Sahiba Kaur​, to the community!
did you follow the Quick Start Guide, section 1 and install it in your local STSW-BNRGLP-DK SW package installation folder?
Did you check it using the projects in the Projects folder as mentioned in section 1.1?
/Peter
