How can use BLUENRG-M2SP with custom board?
I've developed a custom board with STM32F446 and BLUENRG-M2SP, but I can't realize connection. I use the same code for X-NUCLEO-BNRG2A1, in particular X-CUBE-BLE2 Sample App and I've changed SPI pin.
If I set the UserBoard mode as HCI_interface, when starting the code the device is unable to define the address and fails all initializations.
if I set HCI_interface as template, initializations are done correctly but I can't find the device with the app.
Can sameone help me?
Thank you,
Angela
