Visitor II
March 3, 2024
Help on reading accelerometer data from STEVAL BCN002v1B
  • March 3, 2024
  • 0 replies
  • 827 views
Good morning everyone, I am new to the field and would like some advice on using your sensors. I am trying to create a script in javascript (I am using noble.js) in order to connect a number N of steval bcn002v1b sensors with bluetooth connection and acquire the data that the sensor provides. I'm having problems retrieving the accelerometer data as I can't get them and i think I have to trigger accelerometer events to then acquire the data. I would therefore like to ask if you have any suggestions on how to do this as even sending buffers to the sensor it does not react in any way. Thank you very much in advance
