FSkro.1
Can't connect to STM32H7 on SEGGER or JLink
  • June 11, 2021
  • 1 reply
  • 1906 views
I can't connect to STM32H7B3I on SEGGER or using JLink. Resetting option bytes on JLinkSTM32 fails. If there is somehow irreparable damage, could that have been due to me programming high or low frequencies (1-400 MHz) in the RCC? If not, what could be the cause?
    1 reply
    Tesla DeLorean
    Guru
    June 11, 2021
    Posted to wrong subforum.
    Try power cycling the H7 with the BOOT0 pin pulled/strapped high, and then try connecting. And mass erasing the flash.
    I​f that recovers the part look at the VOS and LDO/SMPS settings in your code.
    Connection under reset requires NRST to be wired​ on the debug header.
    FSkro.1
    FSkro.1Author
    Thanks. Where can I find the boot0 pin on my model?
    Tesla DeLorean
    Guru
    June 11, 2021
    Don't know what board and connections you have. The data sheet would enumerate the pins.
