skuma.8
Avaialability of xt2046 based touch ic library
  • May 19, 2023
  • 4 replies
  • 1294 views
Hii everyone,
i am working with a 2.8 inch spi display, using ili9341 display driver, adn it is having xt2046 touch driver on it.
Can anyone please guide me for the right and stable library available for using xt2046..
i am unable to find any
    Tesla DeLorean
    Guru
    May 19, 2023
    Seems to be plenty of source materials for a port on the interwebs.
    Failing that pull the data sheet, and have someone on your wider team code one.
    skuma.8
    skuma.8Author
    can u please refer some links....
    Peter BENSCH
    Mostly XPT2046 is wrongly called XT2046. Maybe your search will be more successful if you search for xpt2046 instead of xt2046?
    skuma.8
    skuma.8Author
    ok thnks for the suggestion
