Measurement problem on VL53L3
Hello, I use a VL53L3cx sensor and API STSW-IMG015. I am having two problems. The first is that in the interruption mode, the VL53L3cx stops sending the interruption after 20 received measurements, speed i2c 400khz. The second problem is that the sensor does not measure a distance of more than 1.8 meters, at this distance it gives chaotic results in the range of 20-300mm, I use this setting VL53LX_DISTANCEMODE_LONG. Tell me what could be the problem?
