Teseo-Suite activation
  • July 12, 2024
  • 8 replies
  • 4487 views
Hello
I need to use full featured Teseo-Suite.
Sending letters to st-teseo-suite-support@st.com remain unanswered.
How could I obtain a full version of Teseo-Suite?
Best answer by Peter BENSCH
The key is machine-dependent and node locked.
Usually, it really only takes one working day to get another one, in the case of a holiday maybe a bit longer.
Good luck!
/Peter
Peter BENSCH
Normally, the team responds within 24 hours, but I have asked again if a response is coming now. I'm definitely keeping my fingers crossed!
/Peter
Peter BENSCH
So, it should be done, right?
ASamo.2Author
Hi @Peter BENSCH
Thanks for quick response.
Yes, I received avtivation key.
I have folowing question: can I reuse same key on diferrent computers, or should I request a new key each time?
Peter BENSCH
Peter BENSCHBest answer
Good luck!
/Peter
Hi @Peter BENSCH
I have the same question and I had sent at least 3 emails for past few weeks.
Those emails remained unanswered.
Could you help me to check my activation request?
Thank you.
Peter BENSCH
@yclin I'm sorry for the delay, but the email address st-teseo-suite-support@st.com is definitely the right one.
Please try again and also check your spam folder in case the reply has ended up there.
/Peter
Hi @Peter BENSCH
I had send the email again, and I recieved following reply.
Also, all the previous request emails end up with this following reply.  But there is no further response or receiving the activation key.
Dear Requestor,
Thanks for your application, we confirm that your request has been taken in charge and you will be contacted soon.
Be sure to use your professional email account for the request.
If you have question or if you need support, please contact: st-teseo-suite-support@st.com
Is there something wrong for the information I provided?
I also check my spam folder. The activation key isn't there.
Thank you.
